use heat storage!
A fan, at the ridge of a greenhouse, ducting into the ground, or under a water or dirt container, will store the heat, and eliminate the need for a window( which is more heat loss, even when not in use, and is expensive). Perhaps lining the duct with insulation could get more of the heat into the heat sink, and less of it wasted in the ground.
